Blazer gear ratio change for Chevy 292 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2012, 11:21 AM
Last journal entry: 1947 Studebaker Pickup M-5 Completed
I have a rat rod with a 1995 Blazer 8.5-10 bolt rear end, with G-80 Eaton limited slip,3:72 gears. This is matched up to a Chevy 292 with a 3 speed Saginaw tranny.
This setup is to low for cruising. 55mph=2500 rpm, I was thinking of changing the rear end gears to a 2:73 or 3:08. Any help/ideas,suggestions would be appreciated......
Old 06-23-2012, 04:05 PM
bullheimer's Avatar
NEVER use credit cards!
http://www.ringpinion.com/ and go to calculator. if you are using a truck rear end you might not even be able to get higher gears like that 2:73 so check what's available. i think under 3 would be a mistake. thought about taller tires?
Old 06-25-2012, 04:18 PM
Thanks, I'll have to think about that one.....
Old 06-25-2012, 08:02 PM
rusthater89's Avatar
It might not fit right because the pinion gear will be too big when changing the gears to a ratio that is numerically lower. You may need a new carrier.
Old 06-25-2012, 08:49 PM
Rusthater
Thanks for the info.....
Old 06-29-2012, 07:29 AM
big gear head's Avatar
High Performance Rear Ends
The 8.5 corporate rear end uses the same 3 series differential for all gears from 2.73 to 5.13. The 2.56 to 2.14 gears use a 2 series differential. It would be much easier for you to find a complete rear end with the gears that you want instead of trying to change the gears in the one that you have. You can not simply take a set of gears out of one rear end and bolt them into another without setting the pinion depth, bearing preload and backlash.
super t10h gear ratio change pcarbuckle Transmission - Rearend 4 12-19-2011 02:38 PM
Gear ratio change question Jim7231 Transmission - Rearend 3 10-30-2009 12:44 PM
Change gear ratio on rear end? mars77 Transmission - Rearend 2 09-14-2009 12:27 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
Gear Ratio change 78Corvette Transmission - Rearend 5 04-11-2003 07:01 PM
