Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - blazer has spark at coil and gas no spark at plugs
Old 02-09-2007, 05:07 PM
wrenchheads wrenchheads is offline
blazer has spark coil gas no spark plugs
don't believe module testing at the store, if it is an intermittent problem the test may not catch it. modules can be affected by temp. and other things. most modules may start working after cooling down then quit again, and work when tested.
