Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - blazer has spark at coil and gas no spark at plugs
Old 02-09-2007, 05:37 PM
ricksautorestoration ricksautorestoration is offline
I tested the coil by taking the coil wire off the distributor and grounding it on the part of the engine and there was a lot of spark then i hooked it back up to the coil and checked my plugs theres no spark there? Wouldent that tell me there is a problem at the distributor? I changed the rotor and the cap looks perfectly fine.
