Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bleed the brakes?
Old 07-04-2006, 11:34 AM
fiddyfofoad fiddyfofoad is offline
re:brake bleeding
the best way to bleed the brakes reequires 2 people. a pedal pusher and a bleeder. first off. make sure your brake shoe adjustment (shoe to drum clearance) is not way out, like matti says, there should be some drag when you spin the wheel. if not, then you're going to have to adjust your clearance with a brake adjusting tool on the adjusting star that it behind the oval rubber plug on your backing plate. by turning the star you will expand your shoes and bring them closer to the drum. when you're sure you have the right amount of drag on all four wheels you can start the bleeding process. first, open the lid of the reservoir and make sure it is full. the best way to visually see air leaving the system is to get a tall glass and fill it half way with brake fluid. next get a length of clear plastic tubing that will fit over the bleeder fitting and run the hose down into the glass. start with the wheel furthest from the master cyl and have your pedal pumper depress the pedal slowly to the floor 4 times and hold it to the floor while you crack open the bleeder fitting and watch all of the air bubbles rush into your glass of brake fluid. with the pedal still down on the floor, tighten up the bleeder valve. you do this until no more air comes out of the plastic tubing. periodically you will have to check the level of fluid in the master cylinder so it does not empty out during the bleeding process. next, you go to the 3rd furthest wheel from the master cyl. and do the same process till you get the same results, checking the fluid level as you go. then the 2nd furthest and finally the closest. typically it will be right rear, left rear, right front and left front in that order. if that doesn't solve your problem you probably need some new parts. good luck.
