Are you using a good set of vise grips? Got any PB Blaster?
Cole |
PB-Blaster is some real good penetrating spray. It work pretty fast also.
Cole |
Put a drill bit in bleeder hole. Use the largest drill bit that will fit. You can even drill out lighttly. Soak bleeder with penetrate and use a good pair of vice grips. The drill bit will keep bleeder from distorting from vice grips. Good luck.
After you spray the penetrating lube, give the caliper a few taps in the bellder area with a small hammer. It seems to help the oil penetrate.
Last resort you can try heating the valve but I dont recommend it.
Artificial Intelligence is no match for Natural Stupidity Chet |
Got a million more.....just gotta wait tho!
![]() I like building up the suspense. |
| setting points on sb chevy | frackster66 | Electrical | 14 | 03-22-2008 11:33 AM |
| replace it vs. fix it (drum brake bleeder) | Bort | Suspension - Brakes - Steering | 9 | 08-07-2005 02:36 AM |
| Q-jet tuning with rpm air gap | 66truck4spd | Engine | 5 | 02-09-2004 07:33 AM |
| Bleeder Valve Broken Off | 71gtx | Suspension - Brakes - Steering | 5 | 01-14-2004 12:04 PM |
| stripped bleeder screw | APACHEMAN | Suspension - Brakes - Steering | 3 | 08-26-2003 10:35 AM |
