Bleeder screw size and ... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2011, 06:41 PM
Babyburr's Avatar
Using a 1986 chevy S-10 rear in my project. Does anyone know what size the bleeder valve is for sure. I think it is a 10mm. Also, where do I get the special tool to unscrew the dang bleeder valve?
Old 01-08-2011, 08:24 PM
LATECH's Avatar
Actually I believe they are 8 mm. you should be able to geton em with a regular wrench, or maybe a short 1/4 inch drive socket, if not go buy a bleeder wrench over at Advance , or auto zone or oreillys
Old 01-08-2011, 08:29 PM
Babyburr's Avatar
Thanks. Yeah, you are right. 8mm, and I was able to use a deep thin wall socket on it.
Bleeder screw locked tight truckboy61 Suspension - Brakes - Steering 8 06-18-2010 07:42 PM
Brake bleeder screw breakage :( ChevelleSS_LS6 Suspension - Brakes - Steering 15 08-05-2009 01:30 PM
Hydraulic clutch bleeder screw henny496 Suspension - Brakes - Steering 13 06-30-2009 01:05 PM
Fluid seeping out of bleeder screw. SuperSport Suspension - Brakes - Steering 13 12-02-2006 10:38 AM
stripped bleeder screw APACHEMAN Suspension - Brakes - Steering 3 08-26-2003 11:35 AM
