Bleeding (again) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2008, 06:35 AM
Last journal entry: Free tires
Bleeding (again)
I read through several pages of searches. Seems I've done what was suggested in most.
New system, front disc, rear drum, new MC, Prop valve and all new lines. Bench bled the MC and using a Mityvac on the rear wheels. So far the right rear is the only one to firm up and no more air. I've run almost a quart through just the rear brakes.
The bleeders all seemed a bit loose in the threads when cracked so I sealed just the threads with heavy grease, I could tell a difference but still sucking air on the left, some fluid but mainly air.
I got to thinking that maybe the seal in the left wheel cylinder isn't seated good and the vacuum is pulling air by it, no leak of fluid since none is in it.
Anyone ever run into that?
Suggestions?
Old 08-06-2008, 09:03 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
I'm thinking it's the L. rear W/C , there's not a kink in the line from the T fitting to the W/C correct. because the R side is OK, that only leaves those two items, line from T to W/C, or the W/C itself.
Good luck,
Rich
Old 08-06-2008, 09:43 PM
Shelby1's Avatar
Steel Dreams
re: Bleeding (again)
Richard
When I use a Mityvac or any vacuum source I always pull the bleeders out and wrap the threads with Teflon tape ,the vacuum WILL pull air around the threads and you can not get a good bleed. Seal them and try again. Good Luck!!
Kenny
Lost your job yet?
Keep buying foreign.
Oh and don't open the bleeders any more than you need to get flow,open too far and you will still get air.
bleeding brakes yragat Suspension - Brakes - Steering 18 07-02-2008 05:32 PM
Brake bleeding made easier jimfulco Garage - Tools 18 07-15-2007 12:16 PM
Brake Bleeding HELP!!!! APalusky Suspension - Brakes - Steering 2 03-24-2007 02:21 PM
Lid on/off master cyl. when bleeding?? murrsue Suspension - Brakes - Steering 7 03-19-2007 04:26 PM
one-man brake bleeding atlantis Suspension - Brakes - Steering 20 08-25-2005 12:54 PM
