Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bleeding Air from system with adj valve.
  #18 (permalink)
Old 12-30-2010, 05:35 PM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Originally Posted by OLNOLAN
You too Al, If you rebuild your self don't forget to hone the cylinder a little bit to give the new seals a surface to seat in. Slick bore and new seals leak every time with me. Tryed it more than once, Duh! olnolan
We are on the same wave length there Nolan. Just finished running the brake cylinder hone down the bore. All i need now is a new kit of seals to go in it. i am guessing most places will be shut in town now for the new yr. Cant be beaten by this. I have solved a zillion other problems of after market mustang parts that dont fit. Just another brick in the wall.
Appreciate your tips. I have had a lot of help from guys like yourself from the other side of the planet. I would not have got this far for sure without. The mustang is similar to our early Fords here in a lot of ways, just annoying at times. I AS they say here, have a shrimp on the bbq.
