Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bleeding Air from system with adj valve.
  #21 (permalink)
Old 01-24-2011, 06:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Have you checked to be sure there's no physical blockage of the port to the reservoir?
If you had an '80-up M/C, the valve shown circled below might be stuck.
Your M/C is an older cast iron unit, so it won't be too likely to have anything other than possibly a residual pressure valve in the port itself.
