Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bleeding Air from system with adj valve.
  #27 (permalink)
Old 02-03-2011, 08:15 PM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Finally we have brakes.!!!!!!!!!!!!!
Well after fitting new seals to MC and bench bleeding, then refitting to power booster and still no rear brakes i decided to pressure test the rear lines with about 10 psi from the air hose. (SEE PIC) i heard air escaping and found that a "banjo" connection was leaking although the bolt was tight. THe end of the flex line to the rear caliper has anOFFSET SEE PIC. i had fitted it the wrong way around and it would not seat evenly on the copper washers. So it LEAKED. No wonder it would not bleed to the rear.
I have just bled the whole system, from long to short using a vacuum bleeder called an "AIRBOY" fitted to each caliper bleed screw in sequence Great piece of gear and "NO LEAKS"
I have no idea how a mustang stops with 4wheel disc brakes, or standard brakes either but now i can fit the steering and hopefully plant the engine and drive this thing.
Well its been a frustrating exercise and thanks for all the tips to help me eliminate one thing at a time. Cant be beaten.
The pedal is now firm.
Cheers
Al.
ID:	52266   Click image for larger version
ID:	52267   Click image for larger version
