Happy New Years
You too Al, If you rebuild your self don't forget to hone the cylinder a little bit to give the new seals a surface to seat in. Slick bore and new seals leak every time with me. Tryed it more than once, Duh!
Appreciate your tips. I have had a lot of help from guys like yourself from the other side of the planet. I would not have got this far for sure without. The mustang is similar to our early Fords here in a lot of ways, just annoying at times. I Cheers Al. |
Wire in the hole.???
Cheers Al. |
Mystified with this m cylinder.
Just a query for someone with trouble shooting experience with master cylinders.
Having gone to four places to find a set of cup seals for this"new" {sitting too long in the car) master cylinder , i am unable to get any brake fluid out of the secondary piston outflow after slow pumping with the screwdriver as a pushrod. Seals are on correctly and the primary piston is pumping as it should when i push the screwdriver into the end of the piston with plenty of fluid out of the line. The only thing i can think of is that there is something missing which has the location of the secondary cup sitting on the wrong side of the filling port. Any clues gurus. Cant afford to pull any more hair out. Al. |
Have you checked to be sure there's no physical blockage of the port to the reservoir?
If you had an '80-up M/C, the valve shown circled below might be stuck. ![]() Your M/C is an older cast iron unit, so it won't be too likely to have anything other than possibly a residual pressure valve in the port itself. Last edited by cobalt327; 01-24-2011 at 06:27 AM. Reason: Add photo. |
Mater cylinder
Hi 327 .The cast iron unit has a port hole in each side of the reservoir which are clear through to the bore. I checked the outlets of each with a piece of wire and they are clear as well. The only valve in the system is a "2psi blue willwood" non return valve fitted directly in line out of the master cylinder on the rear part or secondary side only. I am going to try and bench bleed the thing with plugged outlets as i saw some guy demonstrating on you tube. He depressed the pistons slowly and waited for air to rise up.
Its a puzzle. Al. |
http://www.rodsnsods.co.uk/forum/tec...-give-up-25639 . Hi I hate to see anyone stumped. so maybe the information in the link above might shed some light on your dilemma , Have a read of it, theres also some good insight to more Hot rodders.
But the way you had yours plumbed to bench bleed above was correct, as long as it was leak-free and tight. Is there a chance that you weren't pushing hard enough on the piston to overcome the resistance of the larger spring that separates the front and rear valves? |
Cheers. Al. |
Cant let it beat me. No joy from Cal Mustang /LA where it was purchased originally. The receipt shows disc brake conversion kit. i assumed the master was the correct one with the kit. Thanks Cheers Al. |
Finally we have brakes.!!!!!!!!!!!!!
Well after fitting new seals to MC and bench bleeding, then refitting to power booster and still no rear brakes i decided to pressure test the rear lines with about 10 psi from the air hose. (SEE PIC) i heard air escaping and found that a "banjo" connection was leaking although the bolt was tight. THe end of the flex line to the rear caliper has anOFFSET SEE PIC. i had fitted it the wrong way around and it would not seat evenly on the copper washers. So it LEAKED. No wonder it would not bleed to the rear.
I have just bled the whole system, from long to short using a vacuum bleeder called an "AIRBOY" fitted to each caliper bleed screw in sequence Great piece of gear and "NO LEAKS" I have no idea how a mustang stops with 4wheel disc brakes, or standard brakes either but now i can fit the steering and hopefully plant the engine and drive this thing. Well its been a frustrating exercise and thanks for all the tips to help me eliminate one thing at a time. Cant be beaten. The pedal is now firm. Cheers Al. |
Glad you figured it out
Well don't that just piss you off. Thats one of them things that happen. Glad you finally figured it out. Should stop on a dime now. Keep up the photos, I like SEEING what folks are working on, way better than talking.
Yep.
It was easier to rebuild the 347 than play with these brakes. Just got to keep on poluggin away until this thing is on the road.Cheers. Al. |
| 96 S10 clutch system- air -bleeding? | 31chevy | Transmission - Rearend | 2 | 03-20-2010 07:04 PM |
| Springless Valve System | sixty9santa | Engine | 9 | 02-13-2009 05:00 PM |
| bleeding new brake system | dar130 | Suspension - Brakes - Steering | 5 | 04-28-2008 10:48 PM |
| Bleeding Saginaw system | HotRod60 | Suspension - Brakes - Steering | 2 | 03-23-2008 01:53 PM |
| Air bag system leaking/bleeding out | artillerystevens | Suspension - Brakes - Steering | 5 | 10-21-2007 12:14 PM |
