Bleeding brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2007, 07:26 PM
mitmaks's Avatar
Last journal entry: Grille
Bleeding brakes
Does it make difference if I bleed brake system while car is on or off. Car has power brakes.
Old 03-15-2007, 10:15 PM
powerrodsmike's Avatar
Wiki Edits: 161
I will assume you are referring to "engine running" when you say "on or off".
It makes no difference to the hydraulics.
BUT!
I sure as hell would not want to be under a running car, wrapping my arms around suspension components to reach brake bleeders while someone who is probably bored and disgusted sitting in the drivers seat, holding controls that might make the car move.
Shut it off
Mikey
BE different....ACT normal.
Gravity bleeding of brakes. BarryK Suspension - Brakes - Steering 25 09-15-2011 05:57 AM
bleeding brakes steel dragon Suspension - Brakes - Steering 4 02-22-2007 08:29 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Bleeding brakes Frisco Suspension - Brakes - Steering 4 10-16-2004 02:22 PM
More Bleeding brakes Screwy Lewy Suspension - Brakes - Steering 7 06-23-2003 08:05 PM
