where do i start, front to rear, or rear to front?
Terry;
Start with the wheel the furtherest away. Right rear,then left rear,right front,left front. Good Luck.````` Troy; 69s Forever |
The only thing the bleeder valve on the master cyl. will bleed, is the master cyl.The only time it needs blead is when it has been empty or upon installation.
If you start bleeding closest to the master cyl. you will be double bleeding the lines at each wheel. You might ask some other professional mechanics there opinion. I`ve been doing it this way for 50 years and it works good. It might be interesting to hear everyones opinion on this subject. Good Luck. Troy; |
[quote]Originally posted by troy-curt:
<strong>Terry; Start with the wheel the furtherest away. Right rear,then left rear,right front,left front. Good Luck.````` Troy; 69s Forever</strong><hr></blockquote> That is how I have been doing it for 30 years and it works great!
I have been going from the furthest first for over 30 years also. It has worked for me. I would look close at the manual that you have. Everyone keeps telling me that things are changing. Maybe that is one of them. Who knows! What year car is it that says to start at the one closest. I can say with quite certainty that you won't bleed the wheels with the bleeder at the MC. I don't care what any book says, I won't believe that will work.
Did I say you bleed the wheels using the bleeder on the MC?
No, I said that my owners manual says to do each wheel in the reverse order to that originally quoted, I don't know if there's a genuine technical reason or if it's just chevrolet being contrary for the sake of it, since the original post didn't state what car or year I was just pointing out that if there is a valid argument for doing it the other way round because of the particular set-up on that car then it's worth trying to find out what the manufacturers suggest. I don't think it's worth taking chances on something as important as brakes! Turning round to someone in traction and saying "well that's the way I've been doing it for 50 years" is little consolation if they crashed their car due to air left in the system by doing it the opposite to the manufacturers recomendation. </Rant mode off> |
On my car there are high lift coil springs in the rear. I tried several times and ways to bleed them. Never could do it. Took it to the shop and they used the "pressurized way". Maybe it was the master cylinder angle, who knows.
We have been down this road in the past but repeating things over and over is the military way to make sure every troop gets it right!! I have several Motors Manuals for many years and many cars and most every one states to start bleeding at the furtherest wheel cylinder/caliper and work to the closest. I have two Cadi manuals and they say the same thing, and my 57 Chevy manual says the same and my Chiltons Early Broncos/F100/150 says the same. And that is what I was taught in the late 40s. Camaros, I have not gone there so if your manual says that, then I will always follow the manual until it proves to be wrong.
Trees |
Trees is right, there is only one way to bleed brakes. I worked at chevy when the camaros came out, I know camaros screw for screw, I don`t even know how many i`ve had apart. Theres 3 apart in my shop now. As stated there is only one way to do it right. The same question is on most certifacation tests.
Troy; |
And as Trees said "do it how it says in the manual" And as I already said, I am not certain that the other way won't work, just that it's not worth taking chances on and maybe it's worth terry double checking a manual for his car/setup to be certain. I don't mind if you want to do it that way Troy, and if it works then great. I don't mind being proven wrong, but if Chevrolet AND Haynes AND another reliable source all say to start front and work away then that's the way I'm going to do iton my car (and have done several times). Just because you have more years of experience than me doesn't automatically make you right (especially as your trying to tell me that my manuals can't possibly have written in them the sequence of words that they do). If you don't believe me, I'll scan them and post them on here if you like. |
Andybird, I am always open to learning, so would you please scan your three referendes so I can add them to my library.
Thanks, mate Trees |
will do, don't have them with me on account of how 1 of them is on the bench in the garage with 882 heads as paper weights holding the pages open, and one of them is with the guy who is rebuilding my TH-350 for me, but I'll bring one of them to work on Monday to scan a couple of pages
Never to old to learn .Watch that brake light warning light it can be very tricky.
Troy; My confused smiley is gone ,guess I used it up????? |
I have been told by some people that some of the newer cars have to be bleed differently. As in not in the order we are used to. I have not seen it in print as of yet, but don't believe it applies to anything pre-ABS. When working on brakes, I will usually follow any reliable manual that I see, just to be safe. If it is something that doesn't sound right to me, I usually investigate further, like to atleast 1 more source. I do know that my Chilton's Mustang 1965-1973 book says RR-LR-RF-LF. Unfortunately I can't think of any Chevy books that I would have to check in. Would like to see where it says another order though. Always willing to learn something new. That's one of the reasons that I read these posts.
