bleeding brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2014, 11:30 AM
bleeding brakes
hi there guys, ive ben doing my brakes on my 72 fairlane aussie assembled.
new mc.
rebuilt calipers.
new wheel cylinders,rear drums.
I bench bled mc,hooked up my lines, bled rear drums, and they were good, so I went to bleed the fnt discs ,bit off a leaks, hose link to caliper, got new washers, no more leaks, started bleeding fnt discs again and I seem to get fluid pretty good but im getting lots and lots of air in the line its seems never ending, hoping I can get some advise as to what I can look at next.Cheers.
Old 02-03-2014, 09:31 PM
hi again, after reading threw all the threds to do with my problem, I found the solution, some1 mention to try an bleed frnt discs by opening valve, push brake,close valve, release brake and repeat, I tried this after an hour or two all the air was out of the lines, an had gd pressure on brake peddle, also checked calipers , they are working well against the rotors and are releasing well so thanks to the answers from those threds cheers.
Old 02-04-2014, 08:39 AM
455olds's Avatar
Thank you for posting your solution. Glad you got it sorted out.
Old 02-04-2014, 08:48 AM
The mobile view is crap
You bled further to closest to the master cylinder, right? The order is RR,LR,RF,LF
Old 02-04-2014, 11:38 AM
hi thanks, I followed my manual for a right hand drive it says, lr rr lf rf as my mc is on the right hand side, however I still think the usa made the best cars in the world 30s 40s 50s and 60s. cheers.
Bleeding Brakes sscardino Hotrodding Basics 5 05-12-2011 10:49 PM
bleeding brakes yragat Suspension - Brakes - Steering 18 07-02-2008 06:32 PM
Bleeding brakes mitmaks Suspension - Brakes - Steering 1 03-15-2007 11:15 PM
bleeding brakes Kurt Suspension - Brakes - Steering 8 10-12-2005 05:26 PM
More Bleeding brakes Screwy Lewy Suspension - Brakes - Steering 7 06-23-2003 09:05 PM
