I've got a question that I should know the answer to.
I'm just not sure so I'm posting it here.
I've installed hydraulic brakes many times and had no problem in bleeding them. None had a power booster though.
On my new project I am installing disc brakes all around and am using a dual diaphram booster/MC combo. It is mounted below the floor.
Here's the question. Do I bleed this system the same way as one without a booster? Will the pumping of the pedal mess up the booster when there is no vacuum on it?
I just don't want to mess the booster up before I get to try out the brakes.
Another question.
Does the adjustable proportioning valve (for the rear brakes) get installed in the line before or after the 2psi residual valve? I have seen diagrams showing it both before and after the residual valve.
Thanks in advance.
Another question.
Thanks in advance.
