Bleeding Brakes?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2006, 07:29 PM
DEUCE
i just put together my camaro with all new brakes and lines as well as booster and master cylinder, i bench bleed the master cylinder , but still cant get the fluid to flow threw the valve to the lines . please help
Old 08-03-2006, 09:21 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
here's a dumb question, but did you open the bleeder screws on your calipers to allow the fluid thru the lines?
JB
Old 08-03-2006, 09:24 PM
880's unite!
Check your connections. Maybe you have a leak somewhere?
Old 08-04-2006, 05:02 AM
DEUCE
didnt see any leaks,yeah i opened the back right bleeder screw. but it looks like i cant get fluid out of the valve that feeds the lines
Gravity bleeding of brakes. BarryK Suspension - Brakes - Steering 25 09-15-2011 05:57 AM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Bleeding brakes Frisco Suspension - Brakes - Steering 4 10-16-2004 02:22 PM
More Bleeding brakes Screwy Lewy Suspension - Brakes - Steering 7 06-23-2003 08:05 PM
Bleeding Power Disc Brakes J J Beck Suspension - Brakes - Steering 4 06-16-2002 11:07 AM
