Bleeding brakes (possible bad booster or master?) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 05:31 PM
RippinRon's Avatar
I'm having problems bleeding my brakes on my 97 Cavalier (definitely not a hot rod). I just replaced my rear brakes (drums, shoes, cylinders and hard lines). I bled the two rear brakes with the car off then I started it and I loose the pedal?
Do I have to bleed all the front brakes also? I've read conflicting things about how to bleed the brakes some say pump them and some say just press the pedal once. Can anyone clarify what the proper procedure would be? Its a 97 Cavalier with abs. I need to get this car back on the road I've been without it for a week
Any help would much be appreciated, Thanks
Old 03-29-2007, 05:36 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Bleed all of them...start at right real...then left rear then go to right front then left front. Pump and hold...open bleeder...then close bleeder...pump and hold , open bleeder....do tghis at every wheel untill you get pure fluid.
Old 03-29-2007, 06:16 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Do it just like Henry said. The pedal always feels softer when the car is running because of the vacuum booster. Thats what is does. It makes the brakes easier to apply.
Bad master or booster ? or something else anthonyc Suspension - Brakes - Steering 4 10-30-2005 09:16 AM
Bad brake booster? NOlowrider Suspension - Brakes - Steering 4 05-26-2005 12:39 PM
brakes new bleed evrything still no brakes master cylinder bad? IHAVECHEVYPARTS Suspension - Brakes - Steering 2 11-12-2002 08:09 PM
1966 Chev PU upgrade to dual master cylinder for existing brakes Bannear Suspension - Brakes - Steering 7 10-23-2002 01:15 PM
bad brakes mustangdave Suspension - Brakes - Steering 2 05-28-2002 02:07 AM
