bleeding clutch in 95 chevy k1500 silverado? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2007, 11:22 AM
can someone please explain to me, how to bleed clutch slave sylinder in my chevy. Detailed explanation is appresiated.
Old 10-27-2007, 04:12 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Welcome to HOTRODDERS.com
Inspect all parts
Slave Cylinder,
Flexible line,
Master cylinder for clutch,
1. Fill master up.
2. Open bleeder valve on slave until all the air is "bled out".
3. Close bleeder valve.
4. Top off with fluid.
"SlowRide66"
"Illegitimis non carborundum"
Old 10-27-2007, 06:10 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Is this one of the trucks where the slave is on the passenger side of the truck??
Getting the slave bled out is not the big thing-----getting the line and the master can prove to be nerve testing.
After bleeding the slave-----jack up the rear of the truck and you may get air bubbles coming back thru the master into the resevoir.
I found this out when I was having clutch issues with my 59 Elky.
(87 Chev truck slave / 88+ chev truck master)
I started to remove the master, and as it tilted down after loosening the attatching nuts------bunch of air escaped into the remote resevoir.
Clutch has been perfect ever since.
Bryan
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
On some model Chevys the bleeder valve on the slave cylinder is below top where it will trap air and you must remove the cylinder leaving the line hooked up and hold the cylinder in a position where the bleeder is at the highest point and then open it.
Old 07-24-2008, 04:59 PM
candlegarden01's Avatar
let is set over night.
been bleeding mine for a month it seems, engine started and stopped, ran through 2 bottles of fluid, 2 slaves 3 masters, and argued with all techs around now Im just riping the whole clutch out it will not disengage while ruining gata be the pressure plate well see.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
K1500 Improved Clutch Bleeding Procedure JvA Transmission - Rearend 7 08-29-2003 08:03 PM
'88-'98 Chevy Silverado dannimo Interior 1 08-13-2003 08:53 AM
95 camero clutch wyotechgrad Transmission - Rearend 4 08-10-2003 01:26 PM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 04:56 PM
