bleeding master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2009, 01:03 AM
I have always bench bleed a new master cylinder. My understanding is that is to get the air out of the master and as most are angled in the car all the air cannot get out and therefore you do it level on the bench and then transfer to the car. In my case the master sits level in the truck under the floor. It has a trans crossmember that means you kind of have to wind the master around it for the install. I have a hole in the floor above the master. What I am thinking of is to install the master in the truck, install the two bleeder lines back into the master, stroke the brake pedal until I see no more air bubbles and then hook the truck lines up and do a normal brake bleed. Am I missing why that won't work.
Old 07-17-2009, 02:37 AM
New Member
Like most things, ****************************************
(Member has been banned for spamming.)
Last edited by cboy; 07-17-2009 at 05:25 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 07-17-2009, 04:26 AM
Last journal entry: 50 Ply wagon
As long as the MC is bled before the brakes are hooked up, it doesnt know if its on the bench or under the vehicle............go right ahead and bleed it .
Old 07-17-2009, 05:24 AM
i have done it on the vehicle successfully Ed
I have seen on tv someone doing it with a syringe and pushing the fluid in through the outside in to get the bubbles out
Old 07-17-2009, 05:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I see no reason your proposed method wouldn't work fine.
Bleeding a Clutch master & slave Bryan59EC Transmission - Rearend 5 08-03-2006 06:16 PM
HELP ASAP - 77 T/A Master Cylinder and Prop. Valve Question Torx Suspension - Brakes - Steering 1 06-26-2006 01:52 AM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Stang master cylinder Old Crow Suspension - Brakes - Steering 3 06-10-2002 12:40 PM
