With the engine off, fill the pump with fluid. Let it sit for a few minutes. Add fluid until it is up to the low, (cold), mark on the dipstick. With the front wheels off the ground, turn the steering wheel slowly from side to side several times, slowly is 8-10 seconds per revolution. Fill the pump as needed to the cold mark. Start the car, do a few more turns, add fluid as necessary. That usually does it.
That is the recommended procedure as specified by a remanufacturer of pumps and racks. http://www.durexpowersteering.com/techtips.html Scroll down for the procedure. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| How to properly mate a GM pump to a Mustang II rack | Centerline | Suspension - Brakes - Steering | 73 | 10-31-2009 11:59 AM |
| Hydroboost brakes and mustang rack | 47chevy | Suspension - Brakes - Steering | 1 | 01-03-2008 06:33 AM |
| Astro column /shaft on Mustang II rack? | staleg | Suspension - Brakes - Steering | 1 | 03-02-2007 11:52 PM |
| 79-93 Mustang rack & pinion? | davedeltadog | Suspension - Brakes - Steering | 18 | 06-06-2006 01:54 PM |
| Which Mustang Rack to Chose | a54f100 | Suspension - Brakes - Steering | 0 | 04-03-2003 05:43 PM |
