Bleeding New Brake Lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 01:45 PM
I just finished installing a distribution block and master cylinder lines to convert my '64 Tempest from single reservoir to dual. I have the master cylinder bench bled. Before I install the master cylinder I want to know what to do with the dual lines to the distribution block. Currently they are filled with air......................shouldn't I fill them with fluid first? If so, how is this done..........syringe?
Old 02-22-2009, 02:00 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Scot,
Put the master cyl. on the firewall, attach the lines to the MC.
bleed the lines at the block, refill the MC.
Rich
Old 02-22-2009, 03:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by richard stewart 3rd
Hi Scot,
Rich
i agree and after you bleed down at the block.you will need to finish bleeding the rest of the system.I have found it best to open the bleeder valves and let them gravity feed till the air is out of the lines.just keep an eye on the mc so you dont let it run dry of fluid or you will have to do it again.hope this helps. cole
Old 02-22-2009, 04:56 PM
man your right on .
i've had trouble bleeding and sometimes the block swaps to one side and you have that mess to fix .
if your not in a hurry , open one bleeder closest , then other side , then the back axle one at a time till fluid only .
as Cole said keep master cylinder full near top with the cap off .
it's like a funnel with a hose , gravity thing.
no sweat
Old 02-22-2009, 06:01 PM
so...........do I hear 2 for bleed at the block and then all 4 wheels and 1 for just hook it up and gravity bleed all 4?
Old 02-22-2009, 06:05 PM
eloc431962's Avatar
Wiki Edits: 37
what we are saying is it is best that after you bleed and get fluid at the block. it will be in your best interest to go and bleed the whole system.and i have learned through the years gravity feed works best. cole
Single flare Brake Lines homesimpsonr Suspension - Brakes - Steering 2 03-20-2008 07:40 PM
Must II brake lines 4EyedTurd Suspension - Brakes - Steering 3 02-25-2008 08:12 PM
testing of new brake lines before putting car back together firstgear Suspension - Brakes - Steering 8 06-25-2006 12:13 AM
brake lines too short after suspension rebuild FiveFeezy Suspension - Brakes - Steering 4 03-10-2004 09:25 PM
Chrome brake lines??? T5Bird Suspension - Brakes - Steering 6 02-16-2004 09:05 AM
