Bleeding power brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2006, 12:24 PM
Longboard's Avatar
Last journal entry: Well she is finally done!!!
When bleeding power brakes, do you need the engine running for the boost, or can you do it without the engine running?
Old 04-08-2006, 12:34 PM
malc's Avatar
Living At The Speed Of Life
I´ve never done it with the motor running.
Two weeks ago I did mine with a vacuum pump,best brake job I even did.
I´ll never bleed brakes again without one.
Old 04-08-2006, 12:57 PM
bleeding brakes
I have never thought about running the engine either, but then I don't pump the pedal. I recently tried Griot's venturi vacuum bleeder- runs off your compressor, simple to use. About $60. Bill
Old 04-08-2006, 02:37 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Done it both ways. I prefer to leave it off, and then start it to check overall pedal pressure.
In a while, Chet.
Old 04-08-2006, 03:56 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Power brakes use the same bleeding methods as regular brakes do.
Old 04-08-2006, 05:54 PM
50 chevy p/u's Avatar
autoglass master tech
You get a better feel of the peddle firmness if the motor is off.
Old 04-08-2006, 07:08 PM
Mechanic
word of advice
if your gonna bleed your own brakes for the first time
make sure your master is full leave the cap off open the bleeders one at a time and wait till you see fluid drip out watch to make sure there are no air bubbles . repeat this four all 4 wheels . reinstall the cap on the master
then proceed to bleed the brakes , ive seen many new masters get destroyed becuase this step was elimanated good luck
Old 04-10-2006, 08:35 PM
Mine was under $20...but took some assembling.
I got the venturi vacuum pump from Harbor Freight (it will go on sale for about $12 sometimes). I then hooked it up to a spaghetti sauce jar with some clear tubing and fittings from Home Depot. I will never do brakes again without it
Old 04-10-2006, 09:37 PM
Wiki Edits: 31
because of the amount of extra preassure that the booster puts out, you could get many tiny air bubbles instead of a few large 1's, making a less sucessfull bleed with the power booster functioning, actully pump brakes to kill residual vacume in booster b4 bleeding.
Power brakes novatech Engine 6 03-27-2004 06:51 AM
Power Brakes, im confused bizkit075 Suspension - Brakes - Steering 10 11-18-2003 12:00 PM
My engine specs-will power brakes work? bak9jo Engine 8 07-28-2003 11:24 PM
power brakes for 68 GS400? 84bird Suspension - Brakes - Steering 1 07-02-2003 06:39 AM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 02:22 PM
