Bleeding Question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2004, 03:12 PM
Last journal entry: 1969 SS Camaro
Bleeding Question?
Ok I am putting new calipers on the front of my 1998 jeep cherokee and when I get done I want to now how to bleed them because I will not have anyone to help me bleed them?
Old 05-03-2004, 04:03 PM
Tazz
how to bleed the brakes
Buy a vacuum bleeder/$30 and follow the instructions that comes with it.
Tazz
Rat Rods Rule!
Old 05-03-2004, 08:40 PM
302 Z28's Avatar
You can buy speed bleeders at most any auto parts store that has the red packaged HELP items. You just replace the normal bleed screw in your calipers with them. Crack them open the required amount and pump away on the pedal. When all the air is gone screw them down. The speed bleeders have a small check valve in them that prevents air from being sucked back in when you let up on the pedal. The main thing you have to worry about is to not let the master cylinder run out of fluid.
Vince
Old 05-04-2004, 12:20 AM
I made a power bleeder out of a $14 harbor freight vaccum pump (a venturi one for AC), some hose, fittings, and a glass jar. It works awesome and is very quick. Would be a good thing to look into if you have a compressor...I also used it for it's intended purpose and purged my AC in an r134a conversion.
