Bleeding Saginaw system - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2008, 08:48 PM
I have a Saginaw box on a pickup. I have a remote reservoir and a type 3 pump (serpentine). I have made all "a/n" hoses, adapted the a/n fittings to the steering box. I am bleeding the system (rack to rack 40 times) and I keep getting small bubbles when going through the "straight ahead" position. I have probably been rack to rack 400 times since I started to try to rectify this. I have absolutely no leaks. I did find one small leak on the return line to the pump, tightened the fitting and I have not run the engine since, I have just been doing the rack to rack thing. Are these small bubbles normal? We have been turning the wheel fairly fast.
Old 03-23-2008, 10:33 AM
powerrodsmike's Avatar
Wiki Edits: 161
Don't worry about it. If you don't hear heavy groaning or have chattering there should be no problem.
Some small bubbles in a new system are normal, especially if you don't turn the wheel slowly. After a few days the air will come out of the system by itself.
Later, mikey
BE different....ACT normal.
Old 03-23-2008, 02:53 PM
Thanks for the advice. Tried the rack to rack thing turning the wheel slowly. Bubbles finally disappeared. The next thing I will try is firing it up. Last time I did that I had foam, foam, foam. p.s. I am using Redline synthetic p/s oil. Thanks again.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Summit Ignition System vs MSD Harley Monster Engine 4 07-22-2007 05:09 PM
Suggestions on a paint system other than PPG camaro freak Body - Exterior 10 04-03-2007 06:32 PM
System One Polishing/Buffing System texczech Body - Exterior 1 12-26-2006 05:27 PM
