blend door on lincoln towncar 1991 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 08:01 AM
Talking blend door on lincoln towncar 1991
When I turn on the a/c, I get hot air instead of cool air. I opened the dash and looked at the plenum assembly and also looked at the blend door movement. It gets open/close when moving the control. But when it opens or closes fully, it does not stop and keep knoking. What could be the problem? Any advice would be highly appriciated.
( I was told that the Air Door Actuator needs to be replaced. That is not an easy job, anyone knows how to open and replaced it?)
[ December 17, 2002: Message edited by: mohdsal ] <img src="graemlins/crash.gif" border="0" alt="[crash]" />
[ December 18, 2002: Message edited by: mohdsal ]</p>
Old 12-17-2002, 08:43 AM
5.0Towncar's Avatar
Post
On my 88 I had the heater core replaced and they busted a small hose.(There is 2 small diamiter black hoses and a larger clear hose) I have to plug the larger hose in for strait heat and unplug it for strait cold, ther is no in between. I don't think I helped, sorry. Steve
Old 12-17-2002, 12:40 PM
F-1Rodder's Avatar
Post
Maybe the adjuster module is broken, giving you all or nothing.
