blend repair question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 10:25 PM
Hi all,
Lets say you successfully blend an area after clearing leaving no edge or 'halo'. If you color sand the slight orange peel and buff the area will it result in the halo effect? Thanks
Old 06-16-2010, 01:13 AM
milo's Avatar
point on positive
don't sand the edge, maybe graze with the buffer and be happy you got so close , nice...
http://www.a2zautoforums.com/showthr...il+panel+blend
Last edited by milo; 06-16-2010 at 02:36 AM. Reason: http://www.a2zautoforums.com/showthread.php?t=3832&highlight=sail+panel+blend
Old 06-16-2010, 08:07 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
the longer you can let the clear dry before buffing the better off you'll be on a blend.
Old 06-17-2010, 11:28 PM
Rag top bird's Avatar
Hot rods are still the king
I would do a lite sand with 2000 and try to stay away from the blend then buff
Old 06-18-2010, 08:25 AM
I've heard bodyshop guys refer to "blending clear" in reference to eliminating the "halo" , anybody know anything about "blending clear", possibly a ppg product?
Old 06-19-2010, 09:51 AM
From what I understand, blending clear is to be sprayed on the edge of the new clear where it blends into the old sanded clear. You spray it when the clear is still wet. It is supposed to "melt" the new clear into the old, so when you buff, you wont have a halo line. I use medium reducer and get the same results. I'm not suggesting you try that, it's just something that works for me. I'm in no way a professional, and I'm sure the pro's on here would probably frown on doing it that way.
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
Basecoat spot repair question ? 1958FordF100 Body - Exterior 7 03-07-2006 10:36 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Seat repair question Stinkin_V8 Interior 1 02-14-2003 08:25 PM
