Blending - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2007, 11:03 AM
Blending
hi,
just a quick question about blending clear, i'm in the process of doing a spot repair and should be ready to clear it this evening.
once i've shot the clear how long do i wait before using the blending agent?
should i leave it for a while to harden or do it almost immediately while the clear is still tacky?
andy
Old 03-22-2007, 05:48 PM
milo's Avatar
point on positive
Not all clears act the same , thats why they are different ... it's a tough question you got going there without a hint of what your using. For the most part you'll need to clear the whole panel or up to a sharp body line with thought out creative masking etc..
It is not going to "melt in" or blend in the middle of a panel at any rate..
Old 03-22-2007, 06:11 PM
thanks Milo
i tested it the other day on an old silver panel using Upol fade out thinners, i sprayed almost immediately after the clear went on and it seemed to do a pretty good job. i couldnt see or feel a difference anyway, the silver may have hidden any lines though.
i found that cutting the required shape in masking paper and placing it about 1/8th" above the surface diffused the edges of the clear nicely making it easier to blend
this time its for real on a dark paintjob, unfortunately i dont have a tech sheet for the clear so i guess i'll just have to wing it.
Old 03-22-2007, 08:13 PM
milo's Avatar
point on positive
check this one for masking ideas
http://www.a2zautoforums.com/showthread.php?t=3832
Old 03-23-2007, 06:21 AM
nice write up there Milo thanks
i wasnt sure about how to do reverse masking but those pics have shown the way
also the 3 stage bridged masking is cool, its funny because the repair i'm doing is in almost exactly the same place as in your write up, on the rear quarter that is. so i was unsure how far out to bring the clear.
i may still use the fade out thinners aswell though as they seemed to give a good result
will let you know how i get on
cheers
Old 03-23-2007, 08:28 AM
Whenever you do a clear blend make sure you let it cure up well before doing any sanding of buffing-the thin edge of that clear is fragile and if you rush the process you'll definately damage it.
Old 03-23-2007, 04:19 PM
i have a few other small repairs to do around the car, once theyre all finished i'll attack it with the polisher, should be good n dry by then judging by how long its taken me to do this one, sometime in 2009 maybe
nason single satge urethane blending? Supa-haole Body - Exterior 22 10-04-2010 04:56 AM
Question on blending paint? JoeySummers84 Body - Exterior 18 02-19-2006 07:55 PM
blending clear jcclark Body - Exterior 10 05-10-2005 02:02 PM
Blending color 78 monte Body - Exterior 4 05-19-2004 09:19 PM
Blending the c/c Wrencher Body - Exterior 12 11-20-2003 12:34 PM
