blending with chromabase - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2009, 10:09 PM
35prog's Avatar
Last journal entry: More photos
I am spotting in a truck with Prowler Purple, it is a VS7 for the sealer. My question is do I use 222s before spot sealing the panel or after? I need to use the dark sealer to get a color match. I also want to use the 222s on the blended areas. Veh has been wet sanded with 400 grit. And I will be clearing with SPI Universal Clear.
Old 11-16-2009, 04:51 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Well....
222 is not a blending agent,it's an ADHESION PROMOTER. Here is the "recomended" Dupont procedure.
Pick either Special Basecoat Blending or Tri-Coat Repair jobs.
Dupont
I have "other" ways of doing this but,These are MY ways of doing it and if your interested,we'll discuss it further.
I personally would go 600 on the sanding and even a gray scuff pad after that as Chromabase won't fill for crap and IF your sanding is not GOOD,it WILL show.
AND,
Unless you still have some of the original base sprayed,It's doubtfull your "new" paint will match.Especally if they mixed a pint or such unless the jobber is VERY good at matching and even then,I doubt it.
Blending Question HardcoreZ28 Body - Exterior 5 07-16-2009 07:02 AM
Dupont ChromaBase BaseCoat tips acquadigio79 Body - Exterior 2 06-15-2009 05:08 AM
Blending color , clearing panel Polish Painter Body - Exterior 5 06-04-2008 09:39 PM
Don't sand Chromabase jcclark Body - Exterior 5 11-01-2007 12:42 PM
Blending lazybones Body - Exterior 6 03-23-2007 04:19 PM
