Blessing in disguise - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 09:19 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
Well i had my transmission looked at at a shop today. Turns out my FMX in my 70 mercury cougar 351c has went for a poop. So i am deciding to go with a C6 . My question is what will i have to change to slide in a C6 in the place of my old FMX . Are they the same length, Bolt up the same, lines in different spots, does the cross-member fit both tranny's? All answers are greatly appreciated.
thanks guys
bill
Old 06-02-2005, 06:58 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
You will have to measure your existing FMX and compare it to the dimensions for the C-6 HERE to determine the changes that may have to be made.
The cooler lines can flow either way if there is only the radiator being used, so there is no real way to hook them up wrong.
If a cooler is to be used you will want to flow into the radiator cooler, and then the external cooler, and back to the transmission.
The front is the feed/out, and the rear is the return/in, on the C-6 transmission.
I couldn't find this information for the FMX.
Old 06-03-2005, 12:22 AM
hey Mat thanks for the info. I am aware of all the hose placements but, am not sure about the length of the C6 compared to the FMX. I must first ask the right people or go out and buy a core , for i need to have one anyways to rebuild. Also i need to know the spline for both my yoke and the spline on the tail of the trany. ( see if they match up ) BUT MY SEARCH CONTINUES ! oh also.... the diagram says FE block / big block / and small block. Isn't a Cleavland and in between from the small and big. Like its not one or the other. If anyone knows what to classify this motor i would appreciate it.
thanks kindly
bill
Old 06-03-2005, 12:47 AM
aka Duke of URL
The 351C has the same mounting pattern as the small block. The 351M/400 has the same as a 385 Series.
Why have you decided to go to a C6? The FMX is more than enough to hold that engine on the street. -BROADER PERFORMANCE- can either modify your FMX or sell you the correct C6 you need.
