Blew a in line fuse installed per GM CD on 75 TA tachometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 06:52 PM
Just bought a new tach for 75 TA and looking at 75 Pontiac CD manual, it says to have a 1 amp line fuse installed. I didn't see any in fuse holder there before we installed it.
It blows the 1 amp fuse so now I'm wondering what amp fuse should the new tach have 5, 10 20 amp or none? I don't want to melt down a new tach.
What has been your experiences on something like this.
Thaanks
Old 08-04-2012, 05:39 PM
in the factory wiring there should be a fuseable link allready in the line which is located as the pigtail that plugs into the distributor this should give the circut plenty of protection
The Following User Says Thank You to Ripper 410 For This Useful Post:
walt03 (08-05-2012)
Old 08-04-2012, 08:27 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
What's a CD manual? Detail would be nice.
The load of the tach should be stated in the instructions. If not use 5 amps.
Then size the wire per the load. #18 minimum.
Then size the fuse for the circuit. 5-10 amps.
vicrod
The Following User Says Thank You to vicrod For This Useful Post:
walt03 (08-05-2012)
Bbc 402 Installed In A 1980 Z28 Camaro What Should Be Installed For Coil Spring Glen Rogowski Suspension - Brakes - Steering 3 06-21-2009 10:57 PM
700r4 built pressure blew line, fixed now no d/od AmcXcar69 Transmission - Rearend 3 04-19-2009 05:58 AM
plz help s15 blew up. 98 blazer tranny blew cani swap engines disice1011 Engine 2 12-02-2008 10:33 PM
I really blew it Berliner Bel Air Electrical 5 11-17-2004 09:50 AM
Blew a brake line today oldschoolrods Suspension - Brakes - Steering 2 06-16-2004 09:30 PM
