blinker - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2002, 10:14 AM
New Member
Post blinker
yea i was wondering how i would fix my right blinker the thing is it doeasnt blink i flip it on and it just stays solid ne suggestions?
Old 11-20-2002, 01:56 PM
New Member
Lightbulb
You might try replacing the bulb. It is possible that the the incorrect buld was used also. Somtimes the 1156 and 1157 bulbs while they look the same they are not. After that I would start looking for a short.
Old 11-20-2002, 04:02 PM
dklong's Avatar
Post
check the bulbs , and also check your flasher,the contacts inside the flasher maybe bad.
Old 11-20-2002, 04:58 PM
New Member
Post
i put in a new flasher and a new blub it might have been the wrong one so i will have to double check that but thanks
Old 11-21-2002, 01:24 PM
awsum34's Avatar
Post
I don't think it would be the flasher. If it was all four corners wouldn't work. I'd say you got the wrong bulb.
Is it just your right front?
Old 11-21-2002, 02:34 PM
New Member
Post
yea its only the front right its just stays solid
Old 11-21-2002, 05:34 PM
Post
i hava a problem with my brake light on one side, the brake light wont come on but the signal and running light does.it has a new bulb but it still doesnt work
Old 11-24-2002, 04:52 AM
dklong's Avatar
Post
how bright is your bulb, and is there 2 elements lighting up at the same time?? if it is you may have a bad ground or a bad socket or a bad bulb? try a bulb first, then try the other things. good luck.
Old 06-23-2003, 02:15 AM
LoudMalibu's Avatar
my lef tblinker is staying on solid, how do i fix this
