Blitz Black ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2004, 07:41 AM
Blitz Black ?
I have searched through old post and did soem research on the paint one thing that I have not found out is what grit should I use to rough up the factory paint before appling The Blitz. I got this info but it did not say a grit to use
#1. If the existing paint is relatively good condition (ie. no peeling paint, no large amount of rust, etc) no primer is needed. Scuff sand the existing paint with extra fine grit sandpaper, wipe surface with a clean cloth and then apply John Deere Blitz Black.
Thanks for the help in advance.
Old 10-06-2004, 10:02 PM
Old enough to know better
General rule for auto painting: If no repairs are necessary, sand the existing finish with 400 grit paper unless the 'p' sheets specifically call out something different.
Old 10-07-2004, 07:01 AM
cool, I did not know if any one that had painted with Blitz black, had the P sheets, and if it said anything different. Its time to go get to work. Thanks again.
