The block (400) is done - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2006, 05:17 PM
dboyett38666's Avatar
Well they finished the block today,and I recently made a post about the 400 block,and got alot of good advice on it,but he said the cylinders cleaned up good,He honed it out,decked the block,and put new cam bearings,and freeze plugs.There is a down side, he said on the 4 cylinders on one side were about 2 to 3 thousands over,He told me he believed it would work because the low side started about 4 1/2 at the bottom of the block.He honed all the cylinders to 4.185,and the bottom measured 4.188,and the other side come out perfect to 4.185.I know that there is a low spot at the bottom of the block,but what I don't know is should I run it,and use a set of file set piston rings.Here are some pics. of before it went to the other machine shop,because I believe the first one I took it to caused my problem,any info will help make a choice on what to do.Thanks for looking,
ID:	10851   Click image for larger version
ID:	10852   Click image for larger version
ID:	10853   Click image for larger version
ID:	10854   Click image for larger version
Old 03-17-2006, 10:40 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Id run it. I don't think it hurt anything. It's below the ring pack and piston rocking won't hurt anything there.
400 small block heads and bore condition hunter258215 Engine 2 06-22-2005 12:36 PM
looking for a good after market 400 sbc block 406 ss monte Engine 4 06-13-2004 08:54 AM
Chrysler 400 BIG BLOCK dj_xtreme Engine 0 09-16-2003 02:46 PM
6"rods in 400 chevy small block 406chevelle Engine 17 06-20-2003 11:14 PM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
