Block Cracked - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2008, 02:50 PM
Block Cracked
Okay so I have a 4 bolt 350 block that I had bored .030 over last year and built with 4 valve relief flat tops. The top end was a bunch of miss matched parts like a pair of demo car heads because thats all I could afford. After winter the block was POURING water into the oil so yesterday I ordered a 435hp Edelbrock topend kit from Lordco. Today I tore it down and found a HUGE 3"-4" crack in the block. It's on the lifter valley side, near the top edge of the #6 cylinder.
Now I'm frustrated and don't know what to do!?!
Can you weld it? JB weld it? If the block's an anchor I'm fine with that. I'll cut my losses and start again. I have about $2,000 to work with and many many options. I could bore another block and reuse the pistons. Would they fit in a 400 block or a 383 build? I could still purchase the topend kit and put it on a rebuilt but stock bottem end I have? I could buy a 350 crate engine? The intentions of the motor are to fit a shortbox 4x4 with a 700r4 and 39" tires. The truck is cursed! Any help would be greatly appreciated.
Old 05-19-2008, 03:04 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Looks like its time to bite the bullet and find another block.
Old 05-19-2008, 04:07 PM
Yes you could weld it,,with a cast or stainless steel rod. But when you could purchace another 350 block for around $100 Why risk screwing up your new heads, and the other components of the engine. If you would have to have it welded it would be esxpensive, and if you have never welded cast before I wouldn't suggest trying it on your engine block. You have to let cast cool very slowly or it will become even more brittle. When I weld cast I pre heat, post heat , and cover in dry sand or cement. Also by being so close to the bore It would probalally distort it and need to be rebored to bring it back into round.
I have seen JB Weld used on the deck surface of a block before , It wound up leaking coolant into all cylinders.
Personally I would buy another block.
Shane
Old 05-19-2008, 05:09 PM
Motor's Out
Okay, the motor's out now I just need to figure out which way is the best way of going about getting a new power plant
Old 05-19-2008, 05:39 PM
start over with a different block. the only time i would consider this type of repair, is a number matching deal. jb weld will hold the preasure of the cooling system, but the stability of the deck would be compromised. you could pin it, then deck it, but thats a lot of money.
sam-missle
Old 05-19-2008, 07:23 PM
Engine Build
Thanks for the insurance help so far, it reassures my thoughts. I got a good look at the block in the garage and the crack is brutal. It's probably beyond welding even if you wanted to. I know where there's a couple 4 bolt 350s I can take in to be bored and reuse the pistons. But other then that I don't know which way to go with this build. I could have the block notched for a 383? I'm pretty sure I want to run a stall this time. I'll probably have to go with some sort of cast heads to meet the budget. Any engine builders advise would be HUGELY appreciated right now. I'm trying to create some sort of small block torque monster with around $2,000 maybe a little more if I have to but it needs help with those tires so a stock 350 wont cut it for me.
Thanks to all!!!
Old 05-20-2008, 09:08 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I posted in the other thread you started but I will do the same here now that i have read the particulars.
I would say you could put together a very stout 383 or 400 short block for 2000 bucks. And probably and even stouter (is that a word?) 355 shortblock.
If you already have the top end then build yourself a real nice bottom end, you are going to need it if you are going to be making a lot of torque and putting heavy loads on the motor.
Old 05-20-2008, 10:09 AM
I don't have a topend, only pistons. The Edelbrock kit would run me for all I have and I wouldn't be able to afford a bottom end.
Old 05-20-2008, 10:28 AM
Double_v23's Avatar
I thought you said you ordered the top end kit from lordco. Did you cancel it or something?
Old 05-20-2008, 10:29 AM
Well yeah, I didn't pay for it... it's only being transferred from another Lordco branch so it can stay in their vasinity
cracked starter bolt hole on block fezz-man Engine 7 07-22-2006 02:12 PM
Small Block ID Help bluesman123 Engine 4 05-23-2006 10:07 PM
Decoding Ford Small block hotrodgs Engine 16 05-14-2006 06:15 AM
409 Block with a cracked Water Jacket 62ImpalaSS Engine 1 04-20-2006 01:15 PM
cracked block kenneth29 Engine 9 03-21-2006 09:59 AM
