If the 8.990" is the dimension of your stack, I think I'd be shopping for pistons with a taller compression height to prevent cutting the block decks so much.
In other words, on a 350 for instance, half the stroke is 1.74", the rod is 5.7" and a good quality piston will have a compression height of at least 1.560". Added up, this makes the stack 9.000" and will prevent having to cut the decks so much to arrive at a zero deck. With zero decks, a head gasket should be used that will measure between 0.035" and 0.045" to allow a tight squish to allow operation with full ignition lead on pump gas without detonation. There are many gaskets available that measure 0.039", 0.040" and 0.041". |
Go with what the "Tech" sez, the 9.00 makes life much eaiser! |
It was my understanding that it was already cut to 8.990"- since his pistons are only .010" out of the hole he can just run a thicker gasket- to get his .040" quench.
We cut alot of blocks 8.990 and with a 3.480 stroke the Wiseco, JE, CP,Diamond pistons if we use a 6 inch rod and the pistons has a 1.250 CH that would be zero deck and on the 5.7 rod their CH is 1.550 which is zero deck.
The same piston and rod combos with a 3.500 stroke crank would be 9.000 deck for zero deck. There has never been a fitment issue with the intake as most of the performance intake gaskets are thin which helps in these cases. Some of the SRP pistons have a 1.260 and 1.560 CH Last edited by CNC BLOCKS NE; 10-28-2008 at 08:12 AM. |
Thanks fellas and apologies for not making myself clear. The block I'm looking at is already cut to 8.990.
CNC, I'm looking at Felpro intake gaskets and see they are mostly 1/8" or 1/16" thick. So I will most likely need the 1/16" as opposed to the 1/8". This will give me enough gap at the front and rear for silicone? Is that what you were saying? |
Many aftermarket pistons consider the deck will be milled and they are already shortened between the pin and crown, but check this dimension upon assembly to be sure. If the crown projects above the deck, this will drive selection of a head gasket that will maintain .045-.050 inch of space between the piston crown and the squish/quench deck of the combustion chamber. Less than this risks collision between the piston and the head, more than this diminishes the effectiveness of squish and quench. Head gaskets can be stacked to get the right dimensions if one can't be found to have the suitable height. Bogie |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| what deck height is best.... | oldskoolmc | Engine | 14 | 08-26-2008 08:41 PM |
| Big block questions, help please??? | 67 sleeper | Engine | 20 | 05-15-2007 04:24 PM |
| Deck Height, Compression Ratio, Head Gasket. | KeithB123 | Engine | 4 | 03-04-2004 09:41 PM |
| deck height | rookie | Engine | 3 | 03-07-2003 06:17 PM |
