Block fill - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 04:57 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Block fill
I found this old thread while doing a search.
400 small block re"performance"build
I figured Id make a new thread rather than resurrect an old one.
Im also got a 400 bored .060 over in the planning stages right now, This is gonna be a pretty strong street motor and probably be used at a dragstrip just for the heck of it.
So far my plans are aftermarket crank and rods, forged pistons and Im seriously thinking about putting a shot of nitrous on it or maybe even a small blower.
But my concern is, Ive been hearing a lot about how 400s overheat easily, especially when bored out. Ive also been told that ones that are bored .060 over aren't real strong because of the siamesed bores. In this thread I found they were talking about block fill. Do you think this would be a good idea on an engine like this to add strength but also not let it overheat?
This will be driven on the street mostly and I definitly don't need it overheating which is why Im asking.
Thanks guys
Brad
Old 01-15-2006, 05:16 PM
BOBCRMAN@aol.com's Avatar
If you only "short fill" the block, heat problems will not be a big factor. Fill the block to the freeze plugs. Lots of these running around on the street.
Old 01-15-2006, 05:27 PM
Gone fishin'
Wiki Edits: 2
Thanks bob, I just wanted to make sure on this.
Appreciate it
Brad
Old 01-15-2006, 05:45 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Excuse my ignorance but ...
What is meant by "short filling a block?"
Rob
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 01-15-2006, 05:58 PM
Gone fishin'
Wiki Edits: 2
This is block fill
It basiclly just fills in the water jackets to add strength to the block.
Brad
Old 01-15-2006, 07:34 PM
Perfectionist Procrastinator
Last journal entry: Moving along
Short Filling refers to filling the block only partially, as opposed to all the way. Like Bob said, up to the freeze plugs.
Supposedly, since the majority of the heat is generated in the top inch or so of the bore where combustion occurrs, filling the block this way doesn't have a significant impact on water temperature, while also stiffening and strengthening the bores.
Old 01-15-2006, 07:41 PM
Gone fishin'
Wiki Edits: 2
Yeah I think I will be putting some block fill in this block just to make sure its good and strong. Any other precautions I should be aware of? Should I let a machine shop fill it or can I do it just by reading the instructions?
Brad
Old 01-16-2006, 12:25 PM
camaroman7d's Avatar
Brad,
Before you run out and fill (short or tall) you need to know a few things. First if the block is already machined, I wouldn't fill it. The block fill will distort the cylinders as it dries and should be done before machine work. The other thing is, you can expect higher oil temps, since there will be no water in the lower half of the block to carry away heat, it will make your oil quite a bit hotter. You can cure this by running an oil cooler.
Royce
Old 01-16-2006, 12:57 PM
Gone fishin'
Wiki Edits: 2
Thanks Royce, The block has been machined already. Ive been meaning to take it to a machine shop to make sure its all good. But Im guessing since its already .060 over, I wouldn't be able to have the cylinders straightened up after the block fill.
Oh yeah I was definitly planning on an oil cooler, with or without block fill.
Thanks
Brad
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
i need a better 400 sbc block 406 ss monte Engine 5 06-21-2004 11:31 AM
looking for a good after market 400 sbc block 406 ss monte Engine 4 06-13-2004 08:54 AM
small block vs big block JUSTINH Engine 28 02-17-2003 04:37 PM
