#1
block filler
I went thru the archives but couldn't find the right thread.
I read some time ago about using sanded grout as a filler and was wondering if someone could point me in the right direction.I have access to alot of this product because I work for a flooring retailer.Thanks
Register now (free) or login to remove ads |
#2
Sanded grout is not the right stuff. You need hydraulic cement (calcium hemihydrate).
#3
Thanks Eric,I couldn't remember what they said except that it would work I was just trying to figure out my options Thanks again |
#4
The Moroso product we used in a 454 block didn't look any different than hardware store fare, but who knows if there's any meaningful differences or not.
I found that rapping hell out of the block with a BIG rubber mallet as it was poured helped to get the trapped air up and out, as well as tipping the block back and fourth- both sideways and fore and aft. |
#5
Sanded grout will actually soften when exposed to water and will make it weak. Thats one reason after laying ceramic tile, you have to seal the grout joints.
#7
FYI, Hardblok (brand name) is just hydraulic cement with iron filings sprinkled in.
| Thread Tools | Search this Thread |
| Similar Threads for: "block filler" | ||||
| Plastic filler tips. | MARTINSR | Body - Exterior | 14 | 03-03-2009 05:11 PM |
| Filler thickness | oldred | Body - Exterior | 8 | 09-19-2007 08:33 AM |
| body line | cole5_0 | Body - Exterior | 13 | 10-14-2005 03:57 AM |
| sandpaper... | 38 special | Body - Exterior | 14 | 10-11-2005 04:30 PM |
| Body Filler do's & don'ts | Ron M | Body - Exterior | 2 | 09-07-2004 05:00 AM |
