Block Filler/Cement - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2008, 06:09 PM
Last journal entry: 1965/66 Impala body lines.
Block Filler/Cement
Seems I'm turning to you guys/gals for help more and more. My latest dilemma is that I found a 454 block that has had all the machine work done on it and the guy I got it from told me it had been bored .60 over. Well my guy at the engine shop miked it today and it's .100 over, but that's not the problem. This is a four bold main block that seems to be in very good condition. Cam bearings have been installed and it seems ready to build. Now, I only paid a pittance for this block and bought it basically sight unseen, but my guy at the shop tells me that it has been partially filled with block filler. Not too full, just enough to give it some strength. It appears to be an epoxy base filler as it is very smooth and black in color and they told me it didn't appear to be cement based. I'd like to use this engine for street use, but want to remove the filler. Does anyone have any idea on how to remove epoxy base block filler?
Old 03-05-2008, 07:25 PM
King of my Man-cave.
Yes. Get another block.
tpm
Old 03-05-2008, 08:18 PM
Wiki Edits: 27
race only
I had a friend that held 4 nhra -ahra records at the same time// they used to fill the blocks with a heat conducting epoxy mixed with glauber salts and only had water thru the heads .
Old 03-06-2008, 06:07 AM
Last journal entry: Bringing home the 401 Nailhead
Maybe good for 1/4 mile trips but not for street use.
Old 03-06-2008, 07:59 AM
bigbadbowtie's Avatar
Bottle Fed
Partial filled blocks are run on the street quite a bit. I would run an oil cooler.
You cannot get the filler out.
Old 03-06-2008, 06:40 PM
Block Filler/Cement
I hadn't thought about the oil cooler. You folks are the best. I feel much better about my purchase now. Maybe a high volume water pump and big radiator too? Thanks for all the input.
Old 03-06-2008, 10:00 PM
Banned
no need to go overkill on the radiator or the water pump, a good oil cooler will be more important/useful. I've seen people run a chevy with just a huge intercooler and no radaitor on the street.
Small Block Vs. Big Block rhanshaw Engine 30 12-26-2007 03:02 PM
Verify a 351w block. Not2psycho Engine 3 05-27-2007 05:23 PM
Big block questions, help please??? 67 sleeper Engine 20 05-15-2007 05:24 PM
Small Block to Big block pullies WakBordr7387 Hotrodding Basics 5 01-30-2007 01:35 AM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 08:44 PM
