Block Hugger Headers for '64 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 05:48 PM
Can anyone recommend a set of thick flange, ceramic coated headers for a small block engine in a '64 Impala? I've looked at several brands but they won't commit to my particular application or they won't fit with side engine mounts. Hopefully one (or more) of you have successfully navigated these waters and don't mind sharing your experience.
Old 04-30-2011, 07:00 PM
techinspector1's Avatar
Wiki Edits: 326
OK, I'm gonna leave myself wide open here and just say straight out....Block hugger/Shorty headers are junk and a waste of your money. Bolt on a set of 1 5/8" long-tube headers with a 3/8" thick flange so they don't curl up like a potato chip as soon as they get hot like those thinner flange thickness junk headers do. I would prefer a 1/2" thick flange, but nobody makes 'em. Right after the collectors, rig up an "X" pipe, then pair off through the mufflers of your choice. The whole idea of headers is to make some additional horsepower and torque and you won't make much difference over cast iron logs with those shortys.
Old 04-30-2011, 07:01 PM
is there a particular reason why you need block huggers? 64 impala specific headers are made
Old 04-30-2011, 08:23 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
have you checked out Sanderson?
they have got some nice stuff.
Old 04-30-2011, 10:07 PM
327NUT's Avatar
Sanderson's are very nice but but for a budget minded individual you can also look at the Patriot headers on the Summit racing website. They do sell some of their units with a 3/8 flange but you have to look for them, most come with a 5/16 flange. I had a set of the ceramic coated 3/8 flange headers but they wouldn't fit my application so back they went. I will say though that they were very well made, the welding was better than Sanderson's especially in the port area....Sanderson's are absolutely trash in the port.
Old 05-01-2011, 07:21 AM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
58-64 Chev headers are tricky because of the x frame. Usually fender well exit or they dump to the side right behind the front wheels.
Old 05-01-2011, 07:23 AM
1930u's Avatar
here you go. http://www.holley.com/2103-1HKR.asp
Old 05-01-2011, 12:53 PM
I used a set of heddman headers on my 63 impala works great
Block hugger headers vs Long tube headers sexypizzaman Engine 12 05-01-2008 01:54 PM
block hugger headers yragat Engine 2 12-09-2007 11:04 PM
Block Hugger Headers vs Regular Headers 63ChevyII General Rodding Tech 7 05-07-2005 10:15 PM
440 block hugger headers gahi Engine 5 11-17-2004 05:36 PM
Ford Block hugger headers Pilot34Coupe Engine 1 02-25-2003 05:18 PM
