Block Huggers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2012, 04:19 AM
Block Huggers
Hi
Can any one suggest a good proformance block huggers for a blown 350 chevy?
Thanks
Old 06-29-2012, 01:42 PM
ericnova72's Avatar
More for Less Racer
There are no performance block huggers, their only claim to fame is for fitment in tight engine bays.
For true performance = long tubes.
Old 06-29-2012, 02:00 PM
Irelands child's Avatar
Commercially available block huggers do just that - hug the block for tight fits as well as ease of installation. For decent performance, you need to look at equal length tube runs and those that are tuned for a particular RPM range that you intend on running your engine - street and/or strip. You also need to factor in tubing size as well. Now, do you want 'decent' block huggers, try Sanderson Headers. If you have good fab and welding skills, build your own and then you can make them as 'tuned' as you need them as well as fit the tight areas
Irelands child
Old 06-29-2012, 09:16 PM
Thanks guys I will have a look at Sanderson Headers and get back to you.
block, blown, chevy, huggers
Ram horns vs block huggers mrl Engine 29 04-25-2013 10:27 AM
Block huggers with GM vortec heads clearance problem. RatPin Engine 14 11-04-2011 09:30 PM
Vortec heads with block huggers dave350v8 Engine 5 02-08-2011 12:39 PM
350 chev block huggers-- headers bettylew Engine 3 07-08-2003 05:43 AM
need block huggers Ed ke6bnl Engine 1 10-10-2002 08:48 PM
