Block I D - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2010, 05:20 PM
Block I D
I have a sbc block the casting # on the rear drivers side is 3932386 the #'s on the front tab are 19n522737 VIOI4FK can anyone help?
Old 10-07-2010, 05:47 PM
BOBCRMAN@aol.com's Avatar
69-78 4" bore. usually 4-bolt main
Old 10-07-2010, 06:50 PM
so a 2 bolt 350 huh.. I was told it was the original 327 but i guess not
Old 10-07-2010, 07:13 PM
ericnova72's Avatar
More for Less Racer
My info shows block casting was used to make either 302, 327, or 350 engines, in 1969. 2 or 4 bolt main depending on application.
The "FK" in the stamped code decodes to 1969 327 2-bolt, originally with a Powerglide trans, in a full size car, 210 hp 2 barrel carb engine.
Old 10-07-2010, 09:32 PM
so its a 327. what are the differences in blocks between 350 and 327. if they both have a 4"bore is it the mains?
Old 10-07-2010, 09:53 PM
ericnova72's Avatar
More for Less Racer
No, just the crank stroke is different, The '68-69 327 is large main journal(2.45") just like the 350 is. 327 is 3.25" stroke, 350 is 3.48" stroke, both have 4.000" bore.
The '62-67 327 is different, it is small journal, 2.30" main bearings. Same 4.000" bore and 3.25" stroke, different size main and rod journals.
Small Block Vs. Big Block rhanshaw Engine 30 12-26-2007 02:02 PM
Verify a 351w block. Not2psycho Engine 3 05-27-2007 04:23 PM
Big block questions, help please??? 67 sleeper Engine 20 05-15-2007 04:24 PM
Small Block to Big block pullies WakBordr7387 Hotrodding Basics 5 01-30-2007 12:35 AM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 07:44 PM
