Block ID - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-21-2008, 01:28 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Look in the middle of the passenger side of the block, it will be a vertical number saying something like D1VE, C8VE, D7VE, etc..... If the exhaust manifold is on it you probably won't see it. Ok that wasn't a intake number, my bad, but i knew it wasn't a block casting number. I heard of that number before but needed some refreshing when you put a picture of it up. About five or six months ago I sold two 460 timing covers and one of them had that exact same number on it. That engine came out of a 77 F250, had a D1VE block casting number, D3VE heads, D6TE rods and a C8SE timing cover.
BTW if you are looking at sb Ford casting numbers they will be down by the starter. A FE engine should be on the drivers side by the oil filter and a 429-460 will be in the middle of the block on the passenger side.
  #17 (permalink)
Old 12-22-2008, 12:39 PM
woodz428's Avatar
Troll Hunter
I don't know about the other manufacturers but Ford used the same timing cover for years, that's why that isn't a good source for dating. I think they only made 2 FE timing covers ( maybe 3, the very first ones may have been stamped steel), aluminum and with only a couple of #'s. The same is true of most other engines,SB and BB.
  #18 (permalink)
Old 12-23-2008, 10:25 AM
Alaskan Assassin's Avatar
America-Home of the $700B Bail
Oh ya, it's D1VE
Thanks for helping me figure that out...
Small Block Vs. Big Block rhanshaw Engine 30 12-26-2007 02:02 PM
Verify a 351w block. Not2psycho Engine 3 05-27-2007 04:23 PM
Big block questions, help please??? 67 sleeper Engine 20 05-15-2007 04:24 PM
Small Block to Big block pullies WakBordr7387 Hotrodding Basics 5 01-30-2007 12:35 AM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 07:44 PM
