I`ve heard the 307 blocks have enough meat to bore to 4 inches, however, I wouldn`t attempt it unless I had the bores sonic checked to assure there was enough cylinder material left after the overbore.
the guy who had it before me had it running for years he said and he didn't touch the motor only when he took it out to change it cause of rod knock. must have been the guy before me
and how much allowable play should be in the rod bearing/crank it is about .002 now on all. rods good or more less? and how about overheating i didn't ask him about that should i get a thermostat that is higher or lower temp? and how about the radiator cap wont that lower the temp of fluids by pressurizing the coolant how much difference will the cap be if i go to a 20lbs cap...? from a 16lbs? |
my first chevy engine ever was when i was 16 i bought a 68 chjevy c-10 long fleet pickup for 2200 bucks at a local chevy dealer, in 1994, it was the 307 2bbl and 3 speed column shift SM326 and the 12 bolt non posi 3.73 with coil spring trailing arm rear suspension
i would definitely have the block water jackets cheked for thickness but i would just go grab a 4" bore block they are dirt common especiall the 3970010 and 014 blocks and were both 2 and 4 bolt and many were high tin and nickle content(010 and 0120 cast in bellhousing area and timing cover area). the 307 blocks werent either thing and noen were 4 bolt either, soend same money on a 4 bore block and you can do alot more with it for the same $$$$$$$ 350, 327, and 302 all same blocks, '68 and '69-'79 |
As long as you don't need to bore your block, I'd continue to use it. It isn't going to "like" an overbore to larger than 4", though. BTW, the stroke is 3.48", I think you have a typo in your first post.
| Small Block Vs. Big Block | rhanshaw | Engine | 30 | 12-26-2007 02:02 PM |
| Verify a 351w block. | Not2psycho | Engine | 3 | 05-27-2007 04:23 PM |
| Big block questions, help please??? | 67 sleeper | Engine | 20 | 05-15-2007 04:24 PM |
| Small Block to Big block pullies | WakBordr7387 | Hotrodding Basics | 5 | 01-30-2007 12:35 AM |
| SBC Block I.D. Casting# confusion | 1Fast65Elky | Engine | 2 | 10-13-2004 07:44 PM |
