Block Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2003, 07:08 PM
bonuts's Avatar
Got Ouzo for touzo
Post Block Identification
How do I identify what engine I have? I have finally got ahold of a SBC for my stock car, to take the place of the Olds 350. What numbers do you guys need to find out what I got. I have two sets of numbers off the block. One is: 395618
Second is: V0410x1
do these #'s help whatsoever? If not what #'s do you need?
bonuts
Old 05-23-2003, 07:15 PM
redcamaro4spd's Avatar
drive it like you hate it
Post
well here is a reliable source, but your id number checks out as either a 350, 327, or 302 from '68 or '69 as either a 2 or 4 bolt main. According to this site, it was probably a camaro engine...thats assuming the first number was not off of the cylinder head...<a href="http://www.mortec.com/castnum.htm" target="_blank">Mortec</a>
There is the site link, check it out for any id stuff, they are pretty good...And I have never seen the type of the second number you referred to before...where did it come from on the engine?
[ May 23, 2003: Message edited by: redcamaro4spd ]</p>
Old 05-23-2003, 07:23 PM
superrodder's Avatar
Post
According to my info a 3955618 block came as 68-69 327 engine.
and 3956618 was a 69-70 302 or 350 block.
your number is 395618 so I suspect you miss read the numbers,check them again to make sure.
either way it looks like a good starting point for a hipo engine,good luck
Old 05-23-2003, 11:11 PM
bonuts's Avatar
Got Ouzo for touzo
Post
OK so I have read the numbers better and have found I missed one as you suspected. It reads 3956618. So either 350, or 302 (I wish a 302)but doubt it.
I have also got the # off the crank and it read 3922442, so a cast med. journal 3.48 stroke. Does the 3.48 stroke mean its a 350, by looking at the pistons I would guess 250, cause they look big.
One more question would this motor have come with flat top pistons? This one has flat tops.
bonuts
Old 05-25-2003, 05:32 AM
BOBCRMAN@aol.com's Avatar
Post
442 cranks are common cast 350, if the motor is 69-70 it would have flat top pistons from the factory, but check the piston tops for oversizes, a factory piston will have a GM number on the inside of the skirt and a letter code on the top such as an F or G or H or K etc. these match the pistons to each bore size.
