-   -   block numberes (http://www.hotrodders.com/forum/block-numberes-24137.html)
78 chevy truck 09-23-2003 07:14 PM
block numberes
3970014
johnsongrass1 09-23-2003 10:32 PM
They look like block numbers to me as well. What's the problem?
78 chevy truck 09-24-2003 09:11 AM
are they good or bad y does it seem soo slow in powere is because of the heads
tnoftsger 09-25-2003 02:50 PM
All that those numbers tell us is that is a 350cid block from between 1970-76. If it seems underpowered, then give us all the specifics about the engine and maybe we can suggest something.
Forsaken502 09-25-2003 06:24 PM
Look for a stamped number on the front of the block, to the left and near the top of the timing chain cover, just under the alternator. You may have to take the alternator off and use a scraper/engine degreaser to read the number. That will tell you where it was made and what type of vechile it was put in, as well as some other info.
78 chevy truck 10-03-2003 05:52 PM
the number is C just by its self
tm454 10-04-2003 06:57 AM
You are looking for more than just a C, there should be like 7 numbers and letters on the flat spot just under the alternator maybe more. Use some emery paper to clean up the flat spot and see if you find more numbers.
for more info try this site, http://www.chevytalk.com/
Todd
Rat Rods Rule!
