Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - block prep work
Thread: block prep work
Old 08-10-2012, 10:29 AM
ap72 ap72 is offline
Banned
Originally Posted by dave350v8 View Post
I did try to undo the bolts near the pan rail as well,they were siezed solid! I also drained bottom of radiator suggested by AP72 but it only drains just above water pump holes! So I knock a core plug in(just under heads) to drain the water.
I was going to use a wire brush on a drill but worried about one of the strands coming out and getting in the motor.
Thanks for everyone ideas!
How can I get core plug out of the water jacket it fell in and down!
Can I leave it in there? I was rushing again not thinking!
With the block dissassembled you can take a pick and try to move the plug to a location you can access it... thankfully I've never hit a frost plug into the block.
You can try to run it with the plug in there but anticipate cooling probems.
