block prep work - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2012, 12:02 AM
block prep work
Hi guys
What do you use to clean old gasket material from the cylinder block when getting ready for dropping new heads on? and when I removed heads some water went into oil ways then into sump,do you recommend changing oil?
thanks in advance?
Old 08-10-2012, 12:23 AM
bullheimer's Avatar
NEVER use credit cards!
absolutely change the oil before you start it back up... or try to start it back up. water in oil or not. don't cheap out. n any scraper will work, or single edge razor blade, esp in a blade holder avail at parts store. wipe with thinner or something first. good luck on this....first engine build? just don't dig the edges of your scraper into the block, keep it square to it.
Old 08-10-2012, 12:31 AM
Thanks for that! good info,I built the engine last year the block was already cleaned im just upgrading to aluminium heads,I need more power now!
Dave
Old 08-10-2012, 01:11 AM
vinniekq2's Avatar
after you run the new heads for a day,change the oil again and do a nut and bolt check
Old 08-10-2012, 06:55 AM
Banned
Originally Posted by F-BIRD'88 View Post
For next time you remove the intake manifold or a cylinder head, first pump out the water from the engine water jackets using a windshield washer pump and some windshield washer hose.
remove the heater hose from the manifold and stick the WWpump hose down the heater hose nipple. it will go down into the cylinder head water jacket. Pump it into a bucket or jug.
Pump out enough water/coolant to get the level below the level of the decks of the block.
Now you won't spill water/coolant down in the oil pan when removing the heads.
Or just drain the system using the petcock on the radiator...
Old 08-10-2012, 06:58 AM
A little less "effort" to accomplish the same thing Lynn (LATECH) is talking about... remove the 1/4 NPT plugs on both sides of the block near the pan "rails". This will drain the coolant from the block entirely. They generally have a 9/16" "head".
Some "buddies" may suggest using a ScotchBrite pad on a right-angle grinder to remove the gasket material. DO NOT DO IT!!! The flat scraper is the best way. Follow it up with a light "dusting" with a medium or coarse wire wheel (cup). Many line mechanics use the ScotchBrite stuff. We ineveitably have to mill an "extra" .005" off a head due to the rounded edges and uneven "plane" they leave behind. If you see a "spark" fly off, it isn't ScotchBrite. It's iron... They do even more unapparent damage to aluminum.
Jim
DoubleVision's Avatar
I use a drill with a wire brush to clean the surfaces. When I'm doing the heads I lay a rag into the intake valley to keep the junk out of the crank case.
Old 08-10-2012, 08:51 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Slight thread hi-jack...
How do you remove these? Mine are stuck and when I tried to remove them the head started rounding off. When I had the machine shop rebuild the shortblock I asked them to replace them, but they 'forgot'. My father in law says the old trick is to replace the bolts with a marine style drain petcock so you never had to unscrew them again (not sure what do to on the road if they start leaking though).
Old 08-10-2012, 10:07 AM
I did try to undo the bolts near the pan rail as well,they were siezed solid! I also drained bottom of radiator suggested by AP72 but it only drains just above water pump holes! So I knock a core plug in(just under heads) to drain the water.
I was going to use a wire brush on a drill but worried about one of the strands coming out and getting in the motor.
Thanks for everyone ideas!
How can I get core plug out of the water jacket it fell in and down!
Can I leave it in there? I was rushing again not thinking!
Old 08-10-2012, 10:29 AM
Banned
With the block dissassembled you can take a pick and try to move the plug to a location you can access it... thankfully I've never hit a frost plug into the block.
You can try to run it with the plug in there but anticipate cooling probems.
Old 08-10-2012, 10:36 AM
I drifted plug into block so I could drain water.
Ive always drifted them in before and used grips to "twist them out"
Do you think it will cause overheating problems then?
Old 08-10-2012, 11:46 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Well, not if you removed them...
Semper Fi
Old 08-11-2012, 04:32 PM
Really good idea,will use that next motor I build!
Thanks everyone for your ideas!
interior prep work S10xGN Interior 1 04-11-2006 08:20 PM
prep work joeguz Body - Exterior 2 04-27-2005 08:34 PM
John Deere BB prep work... Fatal_charm Body - Exterior 5 09-26-2004 08:13 PM
prep work for new paint camino_man Body - Exterior 1 01-04-2004 07:16 AM
prep work for powder coating mike bryan Body - Exterior 11 05-15-2003 03:17 PM
