Block prep work again - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 05:25 PM
Hi,thanks to everyone with advice! one final question:
The block has the water level just in the bolt hole threads can i just replace bolts with sealer on them even though they will screw into the water filled hole,had real problems draining the rest of the water out!
thanks in advance
Old 08-11-2012, 05:44 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I think the water will dilute the sealer somewhat at the bottom of the threads, probably not a huge deal. If you can't tip the motor, I'd suck the water out somehow.
Semper Fi
Old 08-11-2012, 05:55 PM
Banned
thanks in advance
Yes, if you're really that worried about it just use white plumbers tape.
block prep work dave350v8 Engine 12 08-11-2012 05:32 PM
interior prep work S10xGN Interior 1 04-11-2006 09:20 PM
prep work joeguz Body - Exterior 2 04-27-2005 09:34 PM
prep work for new paint camino_man Body - Exterior 1 01-04-2004 08:16 AM
prep work for powder coating mike bryan Body - Exterior 11 05-15-2003 04:17 PM
