After machining we use the hot tank for about 20 minutes. After it comes out we have a mix of Dawn dishwashing liquid and hot water at the ready. The block is scrubbed in every orifice with a selection of bottle and bore brushes and scrub pads. Every inch is cleaned over and over. The block and passages are then rinsed with hot water to remove residuals then blown dry throughout and then sprayed down with a light lubricant to prevent corrosion. They are then installed on a stand and bagged.
