Blocking 2-3 Accumulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2009, 10:02 PM
Jakeshoe mentioned in his TH-350 Tech article that the 2-3 accumulator can be blocked by blocking the hole in the valve body separator plate or by replacing the spring with a dowel. Can the hole in the separator plate just be plugged with a zap from the MIG then filed smooth?
Old 01-04-2009, 10:35 PM
jakeshoe's Avatar
If you can mig the plate without warping it, you are better than me.
I put a 3/8" nut over the piston after removing the spring. Usually the nut, a flat washer (5/16") and then the e-clip.
Old 01-07-2009, 05:47 PM
Thanks for the feedback. I like your way better.
Old 01-09-2009, 07:14 PM
what should we do with the 1-2 acc. ?
Old 01-09-2009, 11:27 PM
jakeshoe's Avatar
Leave it as is. Be sure it has a good spring in it, drill the 2nd feed hole to .125" and that's it.
700r4 accumulator question oldchevy1956 Transmission - Rearend 2 05-04-2008 04:43 PM
Blocking! Steve UK Body - Exterior 22 11-11-2007 07:47 AM
How should I go about blocking multiple shapes on the same panel? Ripped Body - Exterior 3 01-08-2007 01:05 PM
700r4 accumulator pistons Elcamino70 Transmission - Rearend 16 12-22-2006 06:22 PM
Accumulator modification TH350? Marcus Transmission - Rearend 2 02-17-2003 11:44 PM
